For over two years now I have to keep a charger on my battery when the machine is on the lift. If I don't battery voltage will gradually drop until the machine will no longer fire up. Even if it is cranking OK, it will not fire up if the battery is down enough that it is showing "low Voltage" on the display. As long as it is well charged, it will fire up and run fine for several hours. But, if allowed to set for a couple of weeks after a run the battery is sometimes down enough that it will not fire, unless put on the charger for a while.
It's possible something is draining the battery in storage, but I think it is more likely the on board charger is not working. How can it be checked out?
Is there a fuse to check?
My '95 XP runs all season with out needing a battery charge. They both have the same batteries and usage pattern (normally both run at the same time). The XP seems to get charged up when running, the GTX does not.
What should I check?
