Battery Charging
AKeuro
Hello all,
I have done some searching but have seen multiple answers, so figured I would make my own post to see what everyone thinks.
I have a 2011 Speedster 150 (155hp) and it is completely stock, no additional stereo components or anything. Just got the boat this year and it has about 16 hours on it. I take the boat out just about every weekend, and usually run it for an hour or two while on the lake. Yesterday when I took the boat out on Sunday (had just been out Wednesday) I went to turn the blower on and the boat would not start. Then I turned the blower off and the boat turned over, but then I got a beep and a '12V LOW' message on the dash. I left the boat running and it was fine for the rest of the day, but it has me concerned. I usually do not have the radio on when the boat is not running, and I know the last 2 times I have been out I have not had it on for more than 15 minutes while the motor was off, and then had a 20-30 minute ride after using the radio. I also always turn the Battery switch to OFF when the boat is on the trailer.
So I am wondering if that is normal with the boat, or if the stator should be charging the battery up more than I am seeing?
Was also considering buying a 'Battery Tender' to hook up while in the garage, but am shocked that I would need to do that when I am using the boat as often as I am.
If I do buy a Battery Tender is it OK to hook it up to the battery in the boat and have it charging as long as I am sure the Battery Switch set to the OFF position? I have heard multiple opinions on this. If I am going to have to hook this up in between trips to the lake, I would rather not have to unhook the battery terminals everytime if it is not necessary.
So to summarize, 2 questions:
1. Does the battery charging behavior above seem normal?
2. Can I hook up a battery tender without disconnecting terminals if battery switch is OFF?
Sorry for the long post, and thanks in advance to anyone who can provide any information.
Thanks,
Kris
In my opinion, based on how you have used the boat, I think that your battery is not holding a charge properly. Since it ran fine once you got the boat started, I think that the charging system is working but more likely the battery is not good. You can pull it out and have it tested at any auto parts store.
I can also tell you that I go out and run the radio for several hours with the boat off and I have no problem starting it. I am sure that won't be true once the battery has some wear on it.
I agree with WaterMaNia.. I keep music "ON" my boat for an hour or so and never had any battery issue..
Yeah, I guess I will pull the battery and go have it tested. Would really hope it is not the battery, since the boat has only been in service for less than 5 months.
Does anyone hook up a Battery Tender or other float charger to their boat at all with the battery installed?
I top my battery up the night before use with a trickle charge (use the boat every 2-3 weeks). The kill switch can be off when charging, provided you connect your trickle charger directly to the battery terminals.
I killed my battery once and had to replace it by leaving the stereo on whilst at home in the garage (volume was off so I didn't notice). If you too have drained yours completely in the past it could have shortened the battery's life.
Charging the battery whilst hooked up in the boat is not an issue - I believe you have to be careful if you jump start a Seadoo, as it's easy to fry the electrics if you have a voltage spike i.e. from a running motor
Perhaps you have a malfunctioning bilge pump float switch, leaving that "on" without your knowledge????
I thought about that as well, but figured if the bilge pump was cycling on and off I would hear it in while it was in the garage.
Battery has never been drained completely, at least not since I have taken delivery of the boat, and I purchased it new. I am going to try and pull the battery tomorrow and see if I can get it tested if I have time, if not I will do it this weekend.
Thanks to all for the information!
Kris
I leave my battery hooked up to a tender 24/7 when not in use. I do this this on all of my toys (atvs, motorcycles, & even lawn mower). As long as you use a quality tender like "Battery Tender Plus" you shouldn't have any problems. I have learned over the years that I like knowing that my battery is 100% charged when I leave the house on what ever toy I choose to use for the day. I have also experienced my batteries lasting longer than normal.
Yea I found its cheaper to get the trickle charger than to have to buy a new battery every time ya turn around LoL.
I hook one on my Ski, lawnmower, boat atv, & my drag car if they sit over like 2 months that Im not using them.
I actually have a timer on the one on my ski (sits the most) cause I found over time I have to top off my battery's again.
OK, pulled the battery out and it tested 100% OK.
Ordered a Battery Tender 800 Waterproof and it should arrive this week. Will keep that hooked up to the boat in between trips from now on and I should be good to go.
Thanks to all for the advice and information!
Kris
