Hey Guys,
So I have a 96' spi 580 motor, I pulled the carb to clean it, put it back together to check compression ( I bought it for $500 with trailer and sold the trailer for $500 ) I pulled 1 plug and put my tester on it and it wont really turn over, like a dead battery but battery is testing 12.9v. So i pulled both plugs and test one side again and it doesnt want to turn over for like a second and then it does turn just fine ( i put wd40 in the cylinders to lube it up as It has been sitting, did this from the start ) , tested both sides and they are 145 psi each. Put the plugs back in and doesnt want to turn over again.... I had this problem one time on my 95' xp after I put in a new wear ring, was to tight for the motor to want to turn over ( easy fix by the way, just use and electric drill, pump out if ski of course, use a impeller removal socket and run the pump with the drill till its eats enough away for a perfect fit, that ski moves now,lol ) So anyways I doubt they put a new ring on it. So does it sound like a bad or weak starter or is there a problem with the lower end or something else? Any input would be awesome....... As always, thanks guys :thumbsup::thumbsup::thumbsup:
