long story short.......
Yesterday I wrote that i couldn't start my GTI.
got a reply that I should check and clean my battery post.
-Today cleaned the post and my starter still wouldn't turn the engine. (maybe 1/4 turn...maybe)
-So I disconnected the starter from the electrical box, after I disconnected the battery and, just for a second, tried a direct connect only the starter to the 12vdc battery and it acted the same as if I were trying to start it normally. The starter would not turn the engine with it directly connected to the battery.
Just to be clear.......no other electrical components were connected to the battery while I tried this test. I was only putting direct power to the starter only to test it.
I took the sparks plugs out of the head, prior to doing the direct test to the starter, and the engine block would turn without the resistance of the cylinder compression.
The battery is good and with this test I believe that the starter is bad.
Does anybody disagree? And if so what could be causing the starter to not allow it to turn the motor over?
