Hey guys, been away for a WHILE! But I'm back now....
So, my port side motor on my 1998 Sportster 1800, which is a 717 with the Mikuni BN-40i-38 carb, recently stopped idling correctly. This is what happened in order...
Last Nov. I took both carbs off, and opened the side with the fuel filter, cleaned everything, and put them both back together. This fixed the "surging" problem I had at full-throttle.
Boat ran good til about 2 weeks ago, other than this. Sometimes when starting, I would have to let the port engine (the problem one) idle for around 1-2mins, before eventually ramping up the throttle, or it would just sputter out and stall. I knew there was some kinda issue, but, eventually when it got going, it would work normally and I could always get it started.
So, 2 weeks ago I was out for a few hours and shut the boat off a few times, for a period of an hour or so, and got it started back up no problem. The last time, I started it, ran about 7 miles at 3/4 throttle (both motors) then shut it off for about 30 mins. This time, I could not get the engine to start, period, it would idle for a sec or 2, then just stall out. I tried, and tried, no dice. Brought the boat back in.
When I got home I noticed that the throttle cable on the port carb/motor, was loose all the way.. I guess the screws came loose over time... I remember reading that the idle adjustment screw works off of the throttle cable tension somewhere.. is this true???
Anyway, I adjusted the tension so it was similar to the other carb, with just a little slack. I also noticed that one of the strands in the cable broke, I guess from the friction of being loosened all the way. Should I be very concerned with this, or can I just cut the one strand back and use it for a while?
Anyway, so the cable tension is good, and I tried adjusting the idle speed, and also re-adjusted the low-speed screw to about 1-1/4 to 1-1/2 turns out. With the flame arrestor off, it seems that it backfires through the top of the carb, I can even see the spark. I checked and the accelerator pump seems to be working, and it shoots a little bit of fuel into the carb when u pump the throttle.. although, I suspect it doesn't work as good as the other carb. The other carb seems to shoot a hard, solid, stream of fuel.. where this one, kinda just sputs some out? is there something wrong with my accelerator pump?
Last night I was able to fiddle with it, and after backfiring a few times, and messing with the mix screw, I got it to run with the garden hose attached. Once it got up and running, it idled right around 3000rpm, and sounded fine and ran normal. I let it sit for a few mins, hit the starter, and it fired back up, no problem??
WTF is going on??? I had it in the water on saturday, after getting is started in the driveway with the hose, and I 100% could not get it started. I am thinking about maybe getting a full re-build kit for the carb, but I don't want to waste my money if this isn't going to fix it. I assume the accelerator pump is part of the carb, and is that something that I rebuild with the rest of the carb? Or is it seperate?
Let me know if you guys have any ideas.. I checked the plugs and they looked oily, but it seems that it has always run rich like this since I got it.. I threw a new set in there and it fired with them, then started doing the same thing.
Do you guys have any ideas? I thought the accelerator pump only does something when you pump the throttle.. so if the throttle was closed all the way, how could the accelerator pump effect the idle and starting of the motor?
This is super annoying cause the other engine runs great and starts right up. I really wanna get this thing to the point where I can count on it.
** just to clarify.. i am only having a problem with the port side motor/carb, and I did take off and clean both external clear fuel filters **
