My 2000XP is still not back to normal.
I removed the carbs again, took the new n/s spring out and replaced it with the old one that was in there before as you suggested timmyboy, cleaned everyting again, and reassembled. That definately helped. The backfiring seems to be fixed, and it starts much easier, but it still will not exceed 3000 RPMs in the water. It will rev to about 7K on the trailer, but even that is not as pepppy as it should be. Other skis I have will fly up the RPM range when you hit the throttle, this one takes a little longer. Its almost as if the high speed fuel circuit is not working at all. I have the screws set as instructed at lsa 1.5 turns out, and hsa all the way in.
I had a question also about something I noticed during the rebuild. When you remove the metering block from the fuel bowl, there is an orifice on one side that seems to contain what looks like a really tiny brass BB. My question is, is that BB supposed to move? I sprayed carb cleaner in what looked to be the other end of that orifice and nothing would pass the BB, it seemed to be fixed in place. Could this be totally blocking the high speed fuel circuit?
I know I am ranting, but after having the carbs off and on about 5 times, I am really frustrated.
Thanks,
Ryan
Thanks,
Ryan
