1st thing battery issue (no biggie), next fouled plugs,.... now the damn thing is smoking in the engine compartment and fouling new plugs.
I am seriously scratching my head. I have wasted 2 long trips to the lake and I'm about to set fire to my ski (fire blowing out each ear 10 feet). Last time i took it out it wouldn't go over 5000 rpm for about 45 minutes... then it ran normal for over an hour but acted up right before i pulled it out of the water.
The next trip i went out and it would barely start. It would only run about 1/2 throttle so I put it up, took it home, and then checked the plugs. They were black and looked fouled.
Today I bought new plugs and headed back out to the lake. The ski fired up fine in the driveway. When i got to the lake and put the ski in 200 feet from the dock it started acting up again and the maint light would blink then go off.
The ski wouldn't start.. hell it wouldn't turn over either...almost like the battery was dead. I had to jump into ice cold water and swim it back to the dock hissing MF-POS with each stroke!
When i pulled it out it started right up but but sounded like crap.
**I opened the hood and there was exhaust smoke in the engine compartment. I turned the engine off... let it clear out then started it again but could not see where it was coming from.
**When I pulled the plugs they were extremely black. (After just a few minutes running??)
smoke in the compartment sounds to me like some exaust connector joint or Gasket is blown/leaking? would that choke the engine out? if there is smoke in the compartment would that mess with air/ratio and foul the plugs??
Can anyone point me in the rt direction?
