Hi I have a 2003 Seadoo sportster 4 Tec 155 having a problem as soon as turn on- off switch boat make the same beep if I had put key in any suggestions?
google "seadoo beeps with no key and starts" comes up with good troubleshooting, sounds like dess post may be bad, there is a way to ohm it out. or corrosion on ECU connectors. good luck
Installed new D.E.S.S post , cleaned all electrical plugs with electrical cleaner and used die electric grease on all plugs . Problem is gone thanks all for help!!
