Guest_User
Lately I`ve been reading problems upon problems with members boats.
people go out and run the boat, when something happens, they either crank the snot out of it or continue to run it if it does refire and do more damage. maybe the issue will mysteriously go away with continued use!
no one likes a failure to occur right in the beginning of the season and it is the busiest time of year for repair shops and part suppliers, so you`ll be waiting quite a while when maybe some issues could have been easily avoided...
Are you doing a pre ride inspection???
checking all hoses, clamps, oil lines and cables, verifying the blower and bilge pump is in working order???
all NAV lighting in working order?
you can be spot checked at any time by the AUX or USCG or local authority.
do you fire the boat up prior to launching? bc no one likes the guy who waits till he`s on the ramp or in the water and their is an issue with the boat possible ruining other boaters day!!!
is the boat on a battery tender?
do you climb under the boat and visually look into the tunnel at the condition of the impeller or impeller boot?
do you frequently spray lube the steering linkage, rear reverse bucket joints, and steering nozzle bushings/bolts???
is the battery cables in good health?
do you frequently check all the ground connections for loose bolts?
if you have electrical issues, broken/burnt/corroded wires or connections??? STOP until this is resolved!!!
You chance your life and others with an explosion if a spark occurs under the hatch.
as our boats age and fuel changes, have you gone thru all the fuel hoses and replaced all of them???
there is so much more to keeping after these jets boats over others. the list is long, but with due diligence a PRE ride inspection and a POST ride inspection a lot of issues can be controlled or taken care of ahead of a catastrophic failure with a little PM = preventative maintenance.
For you NEW to boats owners! get to know your boat, get intimate with it. it is not fun breaking down while having the family on board expecting to have a great time and the next thing your being towed in! there are precautions to take for being towed in as well...
I suggest anyone new research and have a owners manual, a shop manual and some common sense.
Not trying to be an AZZ, but there are always some who should not wrench on their vessel. please recongnize this and leave it to the pro`s. In this case get close with a shop and stick with them, longevity and loyalty does have it rewards in most cases.
many out there are willing to learn, many have a mechanical skill for an advantage over most, but the forums simply can`t repair everyone`s craft.
when seeking help on the forums be sure to always say what boat you have, year/model/size/engine. all that is important for others to help out.
Please wrench and ride responsibly and have an enjoyable summer!
the reason I remind others of this is that I witnessed an unkowning NEW jet boat owner who was told the boat was perfect. The new owner started up the boat on the ramp, left the bulkhead and about 25 feet out it quit. The NEW owner did not recognize the fuel and oil in the water all around him as he continued to crank over the engines with several back fires.
I came about this as we came into port/dock and saw all the gas/oil in the water...
then the NEW owner wanted to continue to self diagnose and crank the engines when I simply said STOP, and a few more words...
Please have common sense with boat ownership, if not I hear skate boarding is safer...lol...
