Uhhh...Clem
I have a 2001 Utopia with Mercury 210 hp M2 Jet. I took the Nozzle Assembly and Stator off with little problems. But, while removing the bolts holding the the wear ring to the drive housing, I broke one of the long SS bolts (the one on the bottom right). It sticks out of the inner wear ring bolt hole about an inch. The Impeller is out, but, I still can't get the wear ring housing to come loose from the drive housing, even using a two-arm puller that I made. So, I am thinking that maybe the broken bolt is holding the wear ring housing tightly to the drive housing?
I tried pushing the bolts through the other inner bolt holes in the wear ring housing, and they seem to be threaded (the bolts screw into them, and don't pull out -- as if the bolt holes are threaded). This doesn't make sense because the wear ring bolts onto the gear drive housing, so, I would think the bolt holes in the wear ring are blank. I am checking here to confirm whether or not the inner bolt holes (next to the drive housing) in the wear ring housing are threaded? If not, perhaps corrosion has formed "threads" in the wear ring housing?
It would be a lot easier to get to the broken bolt if I could get the wear ring housing off first. Otherwise, I am about to begin drilling the SS bolt out of the wear ring and drive housings. Does anyone have any experience with this?
Thanks,
Jim
Thanks,
Jim
