Jim Dawson
While trying to find the problem why my 97 Challenger has trouble coming off idle after it warms up I first rebuilt the RAVE valves and then totally removed them and covered the hole with a plate and gasket. Guess what, the boat revs almost 1000 rpm faster with the RAVE valves removed than with rebuilt valves (and I had a dealer check the valves after I rebuilt them - the dealer also rebuilt the carbs and replaced the impeller). It doesn't have quite as much low end power without the RAVE valves but its a jet so it goes forward by blowing water out the back, not by screwing it's way through the water -right? I still have a problem with coming off idle when it's warm (it might take 30 seconds to plane) but I don't think it's a RAVE issue since it does OK when it's cold.
What's the infatuation with RAVE valves? I'll take top end. Do I risk any damage?
Also, there's a RAVE looking valve controlling water into the waterbox. Can anyone tell me what that's all about and could that be the problem why the boat has problems reving after it's been running for a while. Should I try cutting off the water to the water box or will I burn something up? I'm thinking that too much water in the exhaust might be keeping the engine from reving.
