Are Module Interchangable
you have to use 95 and older. 96-up require a dess key. some 95 720 modules are listed as not for use with 580 motors, but you can retard the timing to get away with it. you have a GTX. should need all the wires. you have all the guages. recheck the timing after replacement. even with correct exact one.
