API-TC oil
SC5561
I have 2 97 GSX skis that I run API-TC oil in and just purchased a 2005 GTI-lE-RFI the manual said to use XPS oil, can I use the API-TC oil in it with out issues I bough it at a dealer and they did not know what oil was in it, it only has 22 hours on it, should I drain the old oil if I switch
You should be using full synthetic API-TC rated oil in all three ski's. If you don't know what the previous owner used you should drain the oil, change the filter and bleed the system. I use XPS2 oil, if you want to go from XPS to XPS2 the oils are compatible.
Lou
