I dont think that is the issue because it works fine at slow speeds. If there was air in there it would not work at all, i think.
There is also a gel like pad on the bottom of the transducer that get compressed when it is snapped in place, so i think that keeps it from vibrating and makes sure there is no air gap.
While i was at the dock i moved the transducer around to see what other spots would work. The only possible area i found was behind the bilge pump. It would read in this spot but it is so tight and not flat there is no way i could epoxy the mount there. Every where else i was able to try must have been to thick because it wouldn't read at all. It is on relatively short cord so i could possibly lengthen that and reach some different spots.
I guess i really need somebody to tell me where seadoo mounts the depth finder on the '09,'10... speedsters. There are some spots that might work but would require some disassembly and i dont want to mess with that unless i know that spot will work.
One more thing about the epoxy. The transducer doesn't have to "read" through any of that because they only put it around the edges. If you look closely at the picture you can see the gray color of the hull on the inside mount.
