i have a 787 engine without the oil add plug on the back of the crank. i have had two problems one i ran the hose without the engine running and the other was the tuned pipe gasket went bad. the motor is reving up and down when i give it throttle and the plugs are wet, but it idles ok. so my thought is the crank has water in it, is there anyway to check? if there is water would it cause this?
thanks jeff
thanks jeff
