Any thing special about the factory Sea doo speedo?
Ironmikea
Greetings,
I completely restored a 2004 Utopia 205 approximately 3 years ago (had the engine rebuilt, redid upholstery, etc.). While doing so, I decided to change the speedo to a new analog Faria Chesapeake gauge. Of course, the speedo doesn't work. When I say "doesn't work", I mean that on power up the speedo needle goes to 0, but it doesn't move when the boat is moving. I'm not sure if the original speedo was working, when I purchased the boat but it was foggy so since I had the dash disassembled, I decided to change it. I don't know if the problem is the sensor or the connection to the speedo. I was going to purchase another sensor and connect it to the harness since this would be easy, just connecting it to the 2 pin connector. Before I chase my tail and take the dash apart again, I was wandering if someone could tell me if there is any compatibility issues which would not allow the new speedo to work. I suspect that Faria will work with any boat. Any insight you can provide will be greatly appreciated. Thanks in advance.
Greetings,
I replaced my Speedo with a Faria years ago, works fine. Slight connection differences. Here is a pic i took, perhaps it may help.
You can check the pickup by measuring a small voltage pulse when you spin it, theres not much to fail on that - magnet & pickup.
Thanks for your response. Faria Chesapeake is a specific model that is different than the stock speedo that you have pictured. I have an electric model which should work with a paddle wheel. I was wandering if someone has connected a different model Faria and was able to get it working. One think that's interesting is the sensor has 2 wires. I was trying to understand how the sensor works since it's only 2 wires.
It is actually quite simple. the two wires are connected to a coil, the spinner on the sensor has small magnets imbedded into it. As the water spins the wheel, the magnets pass across the coil inducing a small voltage/frequency proportional to speed. Your indicator simply translates this sensor output.
Some Speed pickup units have 3 wires - the extra one is for a temp sensor which is a variable resistor that changes electrical resistance proportional to temperature.
So you see, easy to test, and not much to go wrong.
Great. Thanks for this explanation. This will help me troubleshoot whats going on. It will at least be able to make sure the sensor is outputing a voltage. What I suspect is that I should be able to use a multi-meter on the AC setting to see an output since I don't have a scope.
Typical failure is the speedometer head, wires to the coil, and the coil itself (corrosion).
