P ple999 Member Oct 7, 2020 #1 Is there any reason I shouldn't move the flush port to a thru-hull fitting up where I can get at it easily? Does anybody know what size plug and threads to replace the original fitting? Thanks
M MacSeaDoo Active Member Oct 7, 2020 #2 The flush port in our boats is the actual exit port of the raw water cooling loop. So as long as you don't: A: Reduce the size of the port B: Put it underwater You should be fine to move it anywhere.
