Well, there isn't really much to the pump assembly. What you see from the rear of the boat is what you need to remove.
But to ensure complete success with your project (and future ones), you should consider signing up as a Premium Member to enjoy the benefits of access to the downloadable shop manuals. Detailed information, torque specs and diagrams all will make understanding and getting the most out of your Seadoo a lot easier.
97's are simple. unhook steering and trim. 4 13mm bolts for nozzle. 4 17mm nuts holding pump on. don't even hafta mess with hoses inside. usually not even glued on with sealer.
