gsxr_trixxr
ok, I've changed all the filters, fuel line and cleaned everything out. when I bought my 01 rx the acc. pump was clogged so i guess they adjusted the carbs to run with it clogged. It's now working. I've ran it several times since I cleaned everything. It ran great until it got up to around 55 or so then it starts to bog down. I can't get to my low speed adjustments to check them but my high speed was adjusted about 2 whole turns out on both carbs. I closed them but, my ski won't even start with them closed I can back them off 1 rotation and it will crank but has some hesitationin low rpm's. would adjusting my low speed to 1.5 fix this or could my carbs be jetted and need a different adjustment. thanks for reading
