ltbordo
Looked all over for a summary of this unusual ignition system and can’t find in on the threads or web in general.
this system does not spark to ground but between the plugs, fires both plugs at the same time, has the coil continuously grounded and is fired by a pulsed 15Vdc signal from the MPEM that it has amplified from a standard magnet and coil trigger mounted along the stator?
this is very different to a traditional 12 Vdc fed coil triggered by a pulsed ground signal from a triggering device firing the spark plug to ground
I have a weak intermittent spark and cannot figure out a way to bench spark test the coil to eliminate it as a bad part. Just taking resistance measurements is not conclusive enough for me to rule it as a good coil or bad coil.
Can any guru out there explain this system to me and give me a way to bench spark test the coil through the wire,resistor cap , and plug using a 12 Vdc motorcycle battery?
All the old components are lying on the bench ready to go.
john in Roswell Ga
john in Roswell Ga
