The thread just got ambiguous. You were talking about Amsoil Injector in mercury boats and Seadoobuddy said he used Amsoil in his PWC but didn't specify which type. I just didn't want anyone to get the impression they should run amsoil injector oil in their seadoo PWC, they should use amsoil low ash which is their Interceptor oil in the PWC rotax engine.
INTERCEPTOR® High-Performance
Synthetic 2-Cycle Oil
Maximum Performance in all recreational
motorsports applications
AMSOIL INTERCEPTOR® Synthetic 2-Cycle Oil is formulated with a
proprietary blend of the fi nest synthetic base oils and additives available
today. This unique AMSOIL chemistry represents a breakthrough
development in the fi eld of two-cycle engine lubrication. The backbone
of AMSOIL INTERCEPTOR 2-Cycle Oil is a specially developed, molecularly
saturated synthetic base oil. This, combined with a robust additive
package, ensures exceptional lubricity, cleanliness and optimum
clean-burning characteristics.
Extensive research and testing, including a full snowmobiling season in
severe Rocky Mountain applications, has proven that wear on cylinders,
pistons and bearings is signifi cantly reduced. And with up to 30 percent
more detergency and dispersancy additives than typical two-cycle
oils, AMSOIL INTERCEPTOR virtually eliminates hard carbon deposits
that cause exhaust power valve sticking, ring sticking and preignitionpromoting
“hot spots” in the combustion chamber.
Applications
AMSOIL INTERCEPTOR Synthetic 2-Cycle Oil is recommended as an injector oil or at
a 50:1 mix ratio in carbureted, electronic fuel-injected (EFI), semi-direct fuel-injected
(SDI) and direct fuel-injected (DFI) snowmobiles, personal watercraft, motorcycles,
ATVs and jet boats, including, but not limited to, those manufactured by Bombardier®,
Yamaha®, Arctic Cat®, Polaris®, Kawasaki®, Suzuki® and Honda®. It is recommended
wherever JASO FC or API TC two-cycle oils are specifi ed. INTERCEPTOR is a premium-
quality replacement for recreational equipment manufacturers’ branded two-cycle
oils. It is compatible with most mineral and synthetic two-cycle oils; however, for best
performance, mixing oils should be minimized.
• Helps prevent hard carbon deposits that cause
exhaust power valve sticking and ring sticking
• Superior lubricity controls cylinder, piston
and bearing wear
• Reduces smoke and odor associated with
two-cycle engines
• Helps prevent plug fouling
• Provides exceptional SAE #4 cold-temperature
fl uidity (-58°F pour point)
• Protects against rust
• Helps prevent preignition from combustion
chamber “hot spots”
