JPass
So our 2012 210 has always had a considerable amount of water come out of the drain plug after we are out on the boat for a while. This weekend I checked a bunch of things and think I've found the source of some of the leaks.
I noticed water coming in from where the reverse bucket cable comes through the transom. I checked the carbon seals while the boat was moving slowly and saw no water leaking from either of them. Not sure if I should have been going faster to test this, but I'll try that next time I'm out.
I saw in another link that the stock plastic cable nuts are a disaster waiting to happen. The link provided in the thread was for an eBay item that comes from overseas.
I found another one that is slightly cheaper and made in Texas, but the part number is different.
Can anyone confirm if this will work before I order it? I'm assuming I'll need 2, one for steering cable and one for reverse cable. I did not see where I would need any others (we do not have the weedless system).
Link to part on Amazon: https://www.amazon.com/SEADOO-STEERING-REVERSE-ALUMINUM-277001729/dp/B00KWHZ29U
