Hello to all.
I have some issues with battery charging from alternator.
Engine is Merc 2001, round engine cover, under flywheel alternator.
There are 2 sets of charging coils and 2 voltage reg's. At 2000 RPM, the upper VR gets too hot to touch after 5 minutes. The lower VR temp barely above ambient. Max voltage @ 2000 rpm is 13.2. Both VRs are in fact connected to battery at solenoid.
1) Is that much temp rise normal?
2) Thru process of elimination, it seems the lower VR is dead even though tach still works. Do these units commonly fail?
3) Are after-market units worth the $? (sierra brand) Merc OEM is $170.
Thanks in advance. Tim75
