squad1
1997 Challenger, single engine.
I have the boat up at the lake and did a test run to make sure everything fired up in the water. Not too bad..
I did the carb rebuild (Minkuni kit) and changed out the oil tank and pumped out the old blue oil. I ran the engine on the hose and added some oil to the carb throats so I could hold open the injector valve. Oil was inching it's way through both lines. When I finished, I had one tiny spot of air left which I figured would work itself out.
After the test run, I noticed that the PTO line has a very large section of air in it. Is this an indicator of a cracked or loose line?
Side question, when I has adjusting the idle on the trailer, I was shooting for 3000 rpm. The needle on my tach sits around the first dot, then 1, dot 2.. would the dot in between the numeral 1 and 2 be 1500 or is that 1000? Thanks
