Adding Second Battery
I use an isolator switch and wire both battery's into it individually. Couple reasons; if one battery is weaker/faulty then the other one will not drain needlessly. I also worry about the charging system getting overworked on a weak battery, with the isolator you can turn the weak battery off and use the other.
