scski
I'm looking at buying a boat with the carbon ring setup, coming from an older style ski with greased/sealed bearing.
I noticed the boot is not straight from the seal carrier to the hull, it is off to one side a bit.
It appears the through-hull fitting may have been replaced as I can see some epoxy at the top of this area. (Doesn't look normal - different material than fg, looks like light gray epoxy)
Can this cause the carbon seal to wear out prematurely?
If so should I try to replace and recenter the through-hull fitting or maybe revert to the greased/sealed bearing setup?
