JJinSC
From the accelerator pump on my doo, there is a short line (small diameter) that runs to a T and then feeds the accelerator nozzles on both carbs. Before the T there is an inline part that looks like a check valve. I was thinking about ordering a replacement for this to fix my small hesitation between low and high RPMs just after a crankup. My theory is that the check valve is letting the gas drain back down into the carbs when the engine is cut off and then that is why I have to feather the throttle upon the first transition to higher RPMS. However, I cannot find this part on the parts finder. Would it be included in one of the items listed as the hose assembly? There is one hose assembly listed as "(recharge)". Also, there is something called a "recharge jet". What exactly is that?? Any advice here would be greatly appreciated.
Thanks in advance.
Thanks in advance.
