jimmaki
I promise, this is not an attempt to start an "which oil is best" debate.
When I was young and stupid and bought my 1998 SPX new, the dealer recommnded and threw in two gallons of XPS mineral oil free. ( hey, that's SPX backwards ) I don't know if full synthetic was even available back then. Anywho, since the engine didn't blow up, that's what I continued to use. What did I know? I was young and stupid.
OK, now that I'm old and still stupid, but reading a lot of threads here, it appears I should be running XPS full synthetic in my 787 RAVE engine. My take is the main advantage is it keeps the RAVEs cleaner longer.
So here's the question. If I have specifically been using BRP XPS mineral oil and want to change specifically to BRP XPS synthetic oil am I going to get congealed gunk like I saw in one message here where they cut open the oil filter and it was full of black jello ... if I don't drain the rotary shaft oil, the oil tank, all the oil lines, the oil injector pump, the injector lines and prime all the lines and the pump. jeeeze. Does BRP really sell two oils under the same name but in mineral and synthetic formulations that can't ever touch each other without ruining your engine? I'm not asking for a cheaper alternative or if AmsOil is better than Mercury oil or anything like that. Allz I want to know is if BRP XPS mineral and BRP XPS synthetic can mix without causing a nuclear reaction that will melt my engine and eat a hole in the earth clear down to China.
If I have to change oil line what are they? They appear clear. All I have is the left over black FI fuel line from the fuel system referb. What sizes do I need and where can I get it?
