Most of us have had problems with the little fastener darts not fastening the seats down to our boats. Many times causing the seats to fly away on the interstate. Well after much research the only solution I've found so far is sticking them down with velcro or replacing the darts to only fail again. I personally am not a fan of the velcro method. So here is my solution.
As with the older sportster/speedster/challenger seadoo jetboats the seats were bolted in from under/behind the seats. So I did the same. I purchased some threaded rivets 1/4 - 20 and a threaded rivet gun. The rivets fit nicely in the same holes used for the darts. Pictures are easier than explaining.
The bolts are screwed in through the engine bay.
I am still trying to find a method for securing the spotter seat cushions.
EDIT!: Make sure you use aluminum rivet nuts or something that will not rust. I recently removed one of my seats and found the bolts were seized in one of the seats because I did not notice the ones I used were plain steel.
