Went to change my carbon seals today and everything related, and also the impellers. When I pulled the thrust nozzles off (venturi?) I noticed two small holes on the inside face that were plugged with rtv. The holes seem to run into the nozzle, there are two of them. Are they supposed to be plugged?
I noticed that my ride plate is shifted about 1/8 to 1/4 of an inch into the water inlet. Could that also be affecting my cavitation issues?
It looks like, at some point, something got caught up in the driveshaft and whatever it was cut some minor grooves through the gel-coat inside the inlet, just in front of where the pump ends up seating. Should I repair that or is that a minor detail. I've been going through all this to figure out my cavitation issues on the right side.
The old carbon and pusher rings are out and look the same as the new ones, I still hope that they are the main problem.
Thanks, Dan.
Thanks, Dan.
