dsw222
Well this was the first full weekend that I was able to spend on my 97 Challenger 1800 and it was a great time! The boat hit 62mph with only my girlfriend and i riding it (speedo, not gps) so these issues shouldn't be affecting performance, but I'd like to get it running as good as possible
I just noticed a few things, and wanted to see if you guys think I have the right idea of how to fix them...
Problems:
#1 - The starboard engine tachs out at 7200 as i believe it should, but the port engine only reads 7000 (See attached pic). Maybe the tach is just off? Or it could be related to the next issue...
#2 - The port engine's throttle cable sticks at 5000 RPM sometimes. I will throttle both engines together until the levers are completely maxed out, but the left tach will only be reading 5000 RPM. But if I move the left lever back and forth a few times, the engine will reach 7000 RPM. Both levers are a bit "sticky", as in they aren't as responsive as I thought they would be.
#3 - The levers are not synced together. If i move both of the levers together, one engine will tach about 1000 RPM higher than the other. For example, in order for the engines to both be tached at 5000 RPM, the left lever needs to be about 2-3 inches in front of the right lever.
#4 - When I throttle the engines, the port side engine tends to stall out. It will get to around 3000-4000 RPM where it beings to sputter a bit, and when i give it more throttle at this point it will stall out. This seems to ONLY be an issue when the boat is not warmed up. I noticed it when i first put the boat in the water and also after we pulled up anchor after swimming for an hour. After the boat has been running a while, the engines throttle up fine.
Possible Solutions:
#1 - Adjust throttle cables to make sure the throttle is opening all the way before the lever hits the top of its range of motion.
#2 - Lube throttle cables
#3 - Sync throttle cables by setting one engine to 3500 RPM and adjusting the other, as outlined in the shop manual
#4 - I have no idea what could be causing this. Maybe my carbs need cleaned?
I'd appreciate any help or guidance you guys can provide! Thanks
Problems:
Possible Solutions:
