So I was out on the bay for about 2 hours, and everything was running perfect. Took a little break and when I went to run both engines again, one of them worked fine but the other would completely cut off after accelerating for 2-3 seconds. Once I brought it home the same engine that was acting up seemed to work fine in the driveway, however some oil was spitting out of both power valves, as well as smoke was coming out of them. Also, earlier in the day when I was running the boat the Oil light turned on, however there was a decent amount of oil left in the tank. Lastly, the engine compartment has always has a slight smell of gas, is this normal? Any knowledge on these issues is appreciated. Thanks for your time.
