jwick86
I have a new 951 motor and installed it. I needed to order a new check valve that goes between the case and the rave solenoid. After a got it I of course tried blowing through it and it was extremely difficult. Yes I was going the right way. My question is how hard should this be to move air through? And where should the check valve be place? Close to the motor, in the middle, or near the solenoid? If this valve is too hard to blow through, won't this create a spike in fuel pressure by blocking or slowing down air flow to the valves and causing that air to go to the pulse line, or your fuel pump?
