Michael Cain
Boat- 96 Speedster with twin 717s. One grey motor, looks newer, and one white motor- the one with issues
I have an acceleration problem- The white motor is slow to accelerate. It accelerates fine up to about 2000 rpms and then really hesitates from there. Seems like a fuel delivery issue but I cannot pinpoint it. Here's what i've done;
- Does not have the grey fuel lines. I've removed both fuel selectors to make sure there is not blockage. Blew through all of the lines as well. No issues here.
- Swapped the carbs from 1 engine to the other. Same motor same issue. Not the carbs
- Ran compression check. 135 +/-10 on all 4 cylinders.
- Purchased degree wheel and verified that the rotary valve was on the correct tube.
- Oil pump lever is lined up with the notch on the block.
-Sparkplugs are not fowling.
-Motor that is having issues feels like it has about 20% less power than the other one.
Question 1-
Does my engine have some sort of water pressure regulator? I saw someone mention it on a 787, I believe.
Questin 2-
If I had a air leak in the crank case, would it cause this issue? (I hope this is not it...)
I want to thank you all for answering my other post! Let me know what you think about my issues
:willy_nilly:
Question 1-
Questin 2-
:willy_nilly:
