Working on a 99 SPX 787. Starts and runs easy on the hose, revs out well. Put it in the water, and starts and idles great, did a few full throttle runs, and it screamed. Then would only rev to about 3k. Still starts and idles great, but won’t rev out past 3k. Gauges did some weird things, so looked at the rectifier, it was aftermarket and poorly wired in, so I replaced that. Still same issue, so I’m thinking time to rebuild the carbs (have cleaned and replaced, tank, pickup, vents, check valves, and filter.) When I look at the carbs the 99 came with accelerator pump carbs, and the ones on it do not have that. So my question I would like to confirm is to jet them for the 99 spec, and 99 needle screw settings and tune in from there? Also, after running for about 25 minutes in the water at 2500-3000 rpms, the battery was drained so also thinking it needs a new magneto assembly. Thanks, and for those who haven’t bought a membership, do it now! I have saved WAY more than it cost in frustration, and real dollars from this group of fantastic folks!
