i removed the unit from the tank and made sure the float is floating and both magnets are there. It has 3 wires one is red with black stripe and 2 red ones, when checking the ohms i put the test lead in the red/black wire and checked each red wire. only one wire gave me any resistance, the other did not. i also checked the wires going into the gauge and was getting 10.6v on them. Just had the pipes welded up and thought i would fix the gauge issue while i had the extra room to work on it. Sorry just don't know where to look at next, any help is greatly appreciated.
