robomatic12
Got twin 787's in my 99 speedster. When I try to accelerate the revs will hang up at 4500 and stumble, if I pull the chokes out while this is happening they will die out completely (Don't think it needs more fuel). If I back off the throttle and come back on it, it will rev up happily to full throttle around 7k rpm. Boat runs great once up in the higher rev range.
What I have done:
Installed new Fram G2 fuel filters
Cleaned out carbs and rebuild with aftermarket kit (Winderosa)
Checked pop-off value, it is set to 30psi on all 4 carbs
New carb base gaskets
Compression is 150psi in all cylinders
New spark plugs BR8ES gapped properly
Where can I find an oem carb rebuild kit+needle/seat? Should I rebuild the accelerator pumps? Should I try to find a new diaphram for the external fuel pumps?
Thank you
What I have done:
Thank you
