My 99 GTX is running rough. Here’s what’s been done:
Carb clean rebuild
(Wouldn’t idle at all after this and would constantly die at low rpm’s. Runs fantastic at mid to WOT)
I then noticed the threads on the choke cable were snapped and it was adjusted completely at the ends of the threads barely hanging on. So I replaced the choke cable.
(Now runs at idle decently when feathering the throttle, I think the idle without throttle feathering is too low, at mid to high 900 rpm’s but sputters out. It now has a little trouble at low to midrange rpm’s but if you feather the throttle a little bit and then hammer it, it screams like normal)
EDIT: I forgot to note that if I play with the choke at low rpm’s (barely pulling it out) it has no trouble but then when I get into it, I have to let the choke back in to let it breathe enough to get the full potential of the engine. It seems obvious that it’s something with the air/fuel or something with the carb but I don’t know what.
Anyone have any ideas?
Carb clean rebuild
