Heres What Been Done.
Fuel Pump Was Pressure Tested And Is In Spec.
Throttle Sensors Were Tested.
Fuel tank Cleaned And Refilled With 97 Oct.
Fuel Filter (If You Can Call It That) Cleaned.
Everything They Can TEst For At A Highly Recomended Sea Doo Tech Guys Shop Was Checked.
He Said Its A Rev Limiter Issue.
But He Does Not Have The PC Hook Up For Sea Doos Said TAke It To A Sea Doo Dealer. Closest One Is 2 Hours Away.
I Looked On The PArts Break Down And I Can Not Even Find A Part Labled Rev Limiter?
Wil lPost Full Sea Doo Tech Guys List Of Checks And Ideas For Comments A.S.A.P.
So If Any One Has Any Ideas Please Help!!
Thank You.
Techs Supplyied Info
Fuel Psi 60 psi Spec 58-60
TPS
1-2= 2.09
2-3= 1.255
CPS .894 Spec. 774-.946
Ats 2.130 Spec 2.280-2.736 Low I Guess?
WTS 1.848 Spec 2.280-2.736 Low I Guess?
Plugs New Proper Gap
Rave Valves All Checked Good.
Checked Plug Connections All Good.
Confirmed It Is A Rebuilt Engine
Flame Arrestor Mesh Installed Upside Down. I Need To Confirm If He Fixed It Or Not.
Broken Bolt In Flame Arrestor. I Need To Confirm If He Fixed It Or Not.
Again Any Ideas Or Fixs Please Help.
Thank You.
TPS
1-2= 2.09
2-3= 1.255
