99 GTX Limited Dies
trebor433
I have a 99 GTX limited that dies abruptly. Pull the lanyard and put it back on and it will start and run fine. Might run 30 sec. and it might run 5 minutes. When it dies, it is dead not like starving for fuel. Any ideas what to check would be appreciated.
There have been known DESS post failures. You can get a new post for about $30.00. This does not require reprogramming.
Also make sure the post is clean, just use soap and water.
Check your battery connections, make sure they are clean and tight.
