mkov608
Hi all. Is there any alternative to removing the tuned pipe to get to the oil injection filter on a 99 GTX limited? I had a 95 XP a few years back and it was easy to get to the filter. The Clymer manual suggests changing the filter every season, but some genius at Sea-Doo decided to put it in a spot where you can't get to it. :ack:
I'd also like to know if sombody knows where I can get a metal pressure test fitting for the jet pump. The plastic Sea-Doo part is too cheap.
One last question. When fogging the motor, where are you spraying the Sea-Doo lube? They forgot to make a hole w/ a plug in the intake silencer.
