99 GTX advice
Eddie'61
Gents, Bought this machine with 95 hours on it. Want to use different 2-cycle oil. Trying to determine the best (easiest) way to drain the old oil. The reservoir is almost full dang it!
why do you want to drain it? you should only use seadoo synthetic 2 stroke oil. it's expensive, but not nearly as much as a rebuild.
if that's not what's in it, pull the oil filter and drain it there. make sure to drain well, refill, and bleed the oil system at the oil pump using the drain screw (7 or 8mm, i think) to get all the air bubbles out.
Where do you get the SeaDoo oil? I new to PWC as well and just bought two. I've been trying to find it in local Bass Pro, but not there>?
Alot of members, have gone to Quiksilver, stuff found at Wal-Mart. Half the price as Seadoo, in same size container...
I found the Quicksilver, used in my boat for a while, but was worried that not using "SeaDoo" oil would hurt the engine. Thanks SkiDoo answed me once again:cheers:
