Well I bought a basket case Gts and put it all together. Got it all back together put the dess key on and nothing, checked the fuses to find the 15 amp fuse blown. Put a new one in and it blows right away. Take the fuse out and the motor will start and run just fine.
Well I checked the stator(charging coil) and it tests out perfect, .5 ohm resistance indicating its not shorted to ground, and puts out 25-40 Vac when running, but the rectifier wasn't charging and tested bad.
Well I got a new rectifier today in the mail that I bought off ebay that was guaranteed working well I installed it and it immediately blew the 15 amp fuse again. I went through all of the checks in the manual again and the stator still tests good and the rectifier tests bad. No charging at the battery and no voltage when red and black are disconnected from mpem.
Did I just get another bad rectifier? If not what else could be the problem? Would a bad rectifier even cause this?
I need a solution asap as I am supposed to be taking this thing to powell soon. The stator tests perfect on the resistance to show it isn't shorted to ground and gives perfect vac readings.
The ski starts right up and runs great so that makes me think the mpem is fine.
There actually is 12.5 volts coming off the red wire on the mpem that connects to the Rectifier. Should it be that way? If not is that what is frying the rectifiers and does that mean the mpem is bad?
PLEASE HELP!!!
Thanks
Nick
PLEASE HELP!!!
Thanks
Nick
