wittyworks
Hi i just bought 2 gti's 1 is a 96 and one is a 99 they are both the 720cc rotax engine. yesterday after making sure they started first we took them to the local lake to test them out and see how they did. at first the 96 would only get up to about 15, but after about ten minutes it got rolling and would get up to around 45. But the 99 would only idle. i also tried to warm it up for a long time and also held the choke to try to warm it up more, but no matter what i did whenever you tried to give it gas it would just die. These are both very clean inside and out, but i think the problem might be that it's either not getting the top end fuel or that the carb screw isnt adjusted right or that the idle isn't high enough. any suggestions?
thanks alot,
Evan Witty
thanks alot,
Evan Witty
