Last summer, ski ran fine all summer. Then it sat on lift for about a month. When I went to take it out of water for winter, engine would not turn over. I discovered the cylinders were loaded with oil. Looks as though the entire oil reservoir leaked into engine. Probably was at least half full.
I have read were seals can go bad. But this seemed to happen without any sign seals were going bad.
The lift I have in the water, does tilt the nose much higher in the air. So the jetski is not level at all. Could this cause the oil to do that?
Can I blow out the oil from the cylinders and then run the ski or would this cause further damage? Is there an easy way without making a complete mess with oil blowing out all over while cranking engine?
I know to change seals, the entire engine needs to come apart. Any easy way around this ?
Any help would be greatly appreciated.
Thanks!
Thanks!
