Rabid
I didn't think to test the stator on the trailer. I fired up the ski after sitting for a week with the battery disconnected. I had run the ski hard two weeks ago with no problems. It turned over a couple of times And quit. I charged the battery and it took a good while to charge up to 13volts. I had a new battery on hand and the ski cranked right up and I did a run on the channel with no problems. I came back to the dock and checked the voltage at the battery at 1500 rpm and got 13.4v. I did some reading up on stators and rectifiers. I had my wife run the ski up to 3000 rpm and got a reading of 14.2v. I checked the continuity on the yellow wires at the mpem and had the wire closest to the front did not show cont,the second wire did show cont with the third wire. When touching the third wire I did not get a clean sound but registered a value.
What I seem to have is a ski that has enough voltage to charge the battery, but the stator can not power the ski hence the dead battery.
Does this sound like I have a stator problem or is there an issue with the internal rectifier also?
