99 gsx limited carb rebuild
dcroller
I am getting ready to rebuild my carbs and was just wondering if anyone had any pics or text on how to rebuild them step by step. thanks for your time dcroller
If you want you could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and privet use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too.
If you need parts for the rebuild check out our "parts" link at the top of the page to in my avatar.
Karl
Carb rebuild...
At the bottom of this post is my signature. There, you'll notice a link to JPX's thread on carbs. Take minute to read it and look the pix over. Then, you can take a look at the other link, "a look inside the 787". Go to post 11.
The Mikuni carb is not a terribly hard carb to rebuild. Take your time, do one side at a time. I suggest you start on the side where you see your fuel lines coming in. This is where the fuel enters the carb. There, you'll find the strainer basket.
The one most important thing you will do is change the spring and lever at the needle valve. The package will come with 2 or 3 springs. Make sure you compare the spring you have to the ones in the rebuild kit. Doing a pop off test is also important. nswillin has a stickie thread on this procedure and how to put one together...........:cheers:
