Charles603
Hey guys!
So our GP800 decided to be glutenous and devoured a power valve (typical of this ski I know). We bought it used from someone 2 months ago and they had assured us that the Wave Eater clips had been installed (that turned out to be a complete lie)...
Anyways I dropped in an endoscope and saw a ridiculous amount of shavings and just assumed Id have to replace the entire top end. However I opened it up today, vacuumed up the debris and for the hell of it pushed down on the seized piston (nothing happened). Pushed down on the good piston and voila it moved! Vacuumed again then pushed the bad piston down and it slid down with the same amount of effort as the good piston..... When I pushed it down I could see large pieces that had wedged the piston and even damaged the edge of the piston...
So here is where I need a little advice please.
See the pics below. Obviously I still need to open up the crank case to inspect and look for metal, take out the piston, get the tolerances measured, pressure test etc .... but I am amazed that there is no scratch on the piston cylinder wall. All marks that you see I can actually rub away with my hand... Yes even that double black mark you see in the photo wiped off with a paper towel. Feels smooth (could still be damaged)...
Where could I take the piston cylinder/sleeve it to have it inspected/measured? What do you think the odds are that the sleeve doesn't need any work and I could just slap in a new piston or even piston ring and be good to go? I even slid my nail around the entire inside of the piston cylinder and it didn't catch on anything... I'm kind of baffled really that there isn't more damage.
