To be honest I wouldn`t have even known hadn`t you mentioned this thing stuck in the hose. So it made me look and do a little research...(thank you) Before I had no reason to research this recharge jet as I was rebuilding the carbs. My carbs were really clean and the boat ran "ok" with the old engines (well I guess as well as it could). I understand it`s function. I also understand that there is very little volume of fuel in the metering/diaphragm section of the carb. I also understand that when the accelerator pump needs to refill upon expulsion it could draw the fuel away from the Carb`s interior volume.
BUT,,, in the last 21 hours of use I have no complaints or directly related issues as a result of this recharge jet being out of the small hose.
I`m guessing that anyone with a driveability issue would investigate why the accel pump doesnt squirt and discover what you did. I didn`t have any issues with the accel pumps, and just replaced the diaphragm when rebuilding the carbs, and the hoses bc they were 14 years old. I`m not to concerned with anything clogging that hose/hoses as I`m running Racor fuel water separators now, and even still ran new regular filters last season.
I could see where this may be an issues with "ON/OFF" throttling in a jet ski, but have no real comparison to absolutely report. With the boat I throttle up and plane out and away we go until we slow down and accel again or come to a halt.
so I`m thinking it`s not disrupting the fuel supply inside the carb. My thoughts are while your engine is running fuel pressure is being made. I also have High Volume Mikuni fuel pumps that replaced the OEM units and maybe that could help, I don`t really know. So far this hasn`t been an issue for the boat...
as long winded as that reply is I hope that helps somewhat.:facepalm::lols:
note: I do have the check valves in the line from accel pump to discharge nozzle.
