New to the forum with an issue thats driving me crazy. I have a 1998 yamaha 760xl. Last year it lost power and I thought it was a fuel problem so I pulled the carbs and rebuilt them which didn't help. Pulled it back out this year put in a new battery, changed fuel filter, bypassed fuel selector valve(read on a forum) new plugs, started fine, put it in the water and it won't rev over 2800ish. Idles fine, but when you start to throttle up it wants to die. Thought maybe I had water in the tank so I cleaned it out put new fuel in w/some seafoam same problem. Seams like I have good spark on both plugs but it will fire right up with the front cylinder plug out but won't with the back one out so I figured front cylinder carb must not be pumping fuel. Took the carbs back out went through the front one (which was full of fuel) restarted it and the voltage alarm went off which i thought was probably was from cranking it for about 20sec to get it reprimed. Idle'd it around for a few mins thinking the voltage alarm would shut off but it never did. Am I chasing the wrong problem? Should I be checking the charging system and would this make it run slow? Going back to the lake in a couple of days with my meter to see if the battery is charging and look for any loose wires or bad connections. What other tests should I do while I'm there? Thanks for any help
